Clio 182 Titanium
Hi all,
Trying to remedy a long time knock on the 182 O/S. When you go over any nasty bumps in the road it knocks at the front OS like the subframe is loose. my garage could find nowt wrong. its been like this a year and sounds dreadful.
Checked everything best I can. wishbones/drop links/top mounts, ball joints & tierods
You wouldnt think a loose knocking rattle type sound would be the driveshaft as its not when cornering or owt just road surface issues.
filmed this just now, foobarred? the driveshaft is loose man, 4mm play in and out and 8mm+ side to side at gearbox end! made me check hub nut, tight as hell so all ok.
I found J&R in Birmingham and they only want £50 for a fully assembled non o-e 'shaft. worth a punt?
cheers,
Seb
cheers,
Seb
