182 lowering springs
Car  Renaultsport Clio 182
how do all? right, i know naff all about cars really so need a little advice.
my 182 has the standard suspensiom (no cup pack) but i've been thinking of lowering it a touch cos it needs it!
can i just fit lowering springs such as Apex 40mm or Eibach Prolines 30mm without needing to change the dampers? if i need to change the dampers & springs too then i may as well save and get coilovers??
dont really want to blow loads so what's possible?
Sarge
you can go 40mm safely without changing dampers. eibach sportlines are highly rated
get eibach sportlines mate they give the uncupped ones more of a drop. you wont need to change the shock, they will be fine.
yep they will be fine before i got rid of mine they did over 10k without problems. i need to invest in some more me thinks
champion! cheers Craig.
i'll be ordering some end of the month me thinks (pay day) - gives me time to find a place to fit them for me
Hiya pal, I'm getting my eibach springs fitted on my 182 on tuesday so if you want will post some pics for you pal.
