182 manifold on a 172
Car  Black 172 MK2
is this just a striahgt forward swap and what sort of price should i pay for the 182 manifold and where is best to get it from. Im guessing that i would see more power from it cooupled with a few other mods (im just thinking of ideas for FCS) Also is there any other work that can be done to the manifold that is worth while.
cheers
brad
P.s is there a better manifold in terms of bhp for £
182 exhaust is by no means "easy" to fit
the going rate for them is around £250-£300
fitting requires the subframe to come off, plus you need a link pipe making up so the manifold mates upto your existing 172 exhaust system
ok, what sort gains are you likly to expect, or is it a case of it makes it more profitable in the long run ie when matched up with other mods. Also are there any further enhancements that can be had with it ie matching etc
I thought the difference came from inlet manifold, told that by mechanic at renault day at dono??????????????
The mechanic was one of the clio cup boys, so i thought he should know!!!!!!
Told me the are bullet proof too...........
well its the biggest difference between the 172 and 182
power, who knows??
Serg said:
so theres no need to get other work done to the manifold?
where the header pipes are welded to the flange, the internal joint needs a bit of tidying up
apart from that its fine
because i wasnt there yesterday, and you dont get a trophy yesterday for something you did today!..........
fraid thats the rules.
You cant ask for a medal at the olympics a day before...."oh go on, i promise i'll win gold tomorrow"
