PH2 172
That's the pic
Of the RH off side shaft.That's the pic
This thread is about the N/S.
It`s in the title.
That's the pic
sorry dadOf the RH off side shaft.
It`s in the title.
sorry grandad
It`s in the title.
Last question. What lengh are inner tie rods? I got some in garage that ill be replacing but dont want to find out theyre wrong lengh after removing them..
Sent from my SM-G930F using Tapatalk
J&R seem to sell from their website too, (http://www.jandrcvjoints.co.uk/renault-clio-2.0-petrol-2003/catalogue/drive-shafts-509)unless I’ve misunderstood your post, which is quite likelyJ&R only sell direct from eBay, Andrew Page will supply Shaftec products.
Im gonna have to, just paranoid because ive had bad luck with clio since i bought it hahJust go for it. (Link will be dead by 2018)
https://www.renaultpartsdirect.co.uk/parts/renault-clio-range/track-rod-kit-inner-172-182/
Thanks. Ill measure ones i got tomorrow.317mm not including the thread that screws into the rack.
J&R seem to sell from their website too, (http://www.jandrcvjoints.co.uk/renault-clio-2.0-petrol-2003/catalogue/drive-shafts-509)unless I’ve misunderstood your post, which is quite likely:smile:. Does anyone know why there is one shaft priced at £29.95 in this link?
Soz to gatecrash this thread, but I have two driveshaft boots to replace and thought I may as well replace the shafts at this price........my car is lowered though, is the issue with this about the boot fouling on the gearbox? And will grinding a bit away solve the issue?
Thanks :up:.
Not particularly, Cooksports low only....
DS21 is a RH 172 cup shaft without a support bearing.J&R seem to sell from their website too, (http://www.jandrcvjoints.co.uk/renault-clio-2.0-petrol-2003/catalogue/drive-shafts-509)unless I’ve misunderstood your post, which is quite likely:smile:. Does anyone know why there is one shaft priced at £29.95 in this link?
Thanks :up:.
:up:Be fine
Steve. Did you drink a driveshaft potion one night not so long ago?
Tidy, thanks! So for my non-Cup 172 I need the other two @ £50 a piece :up:. A shaft for less than £30 would've been mint though :yum::smile:!DS21 is a RH 172 cup shaft without a support bearing.
Lol, and I'm a pussy on track so the J&Rs should be good :tongueclosed:.But if it helps I give it death from cold and no bend taken unless 67 degree turning angle.
Frankly, I don't know how my car is still going! Engine makes funny noises, gearbox whines, occasional crunch into 4th, and it spends it's life bouncing off the limiter :grinning:. The new shafts will prob hold it all togetherwhat could possibly go wrong :/
How so ?Im gonna have to, just paranoid because ive had bad luck with clio since i bought it hah
I paid £2500 but was so keen on owning it, I've not checked everything properly. I could of returned it but couldn't be arsed. Will just slowly fix her up how I want.How so ?
If you paid £800 for it and thought it would be like brand new, you will be disappointed.
An £800 example will require £1k spending on it immediately, and then budget £1k a year to keep it in shape.
What do you mean on your second sentance?That`s not over the top for a good example, and it will hold or even gain value if you stay on top of it.
The only other problem other than this split boot was a sticking caliper?
Ahh. Pads were seized in, replaced front pads and discs and cleaned carriers out, sorted it.I saw you posted about a problem with the front calipers sticking.
I assume you sorted that?
TBH, that`s not unusual if it was stood on a forecourt for a while.
Theres a few more things I need to do, oil leak from gear selector shaft, sump gasket, poly bush ARB and steering rack bushes, poly bush dog bone.
Then cosmetical stuff: side repeaters different and one is cracked, headlight washer blanks, wheels refurb, replace piece of seat where my mate dropped superglue on, sort scuffs and scratches, fabia splitter, high level brake ligh and number plate lamp, front bumper respray, replace speedo lights to white.
I think that's it [emoji3]
Apologies for digging up again but J and R only sell one type for the 182, anyone know if these will fit a 182 cup pack, thanks?
182’s use the same shafts just with different width ABS rings. You will need the wider one with cup pack suspension.
