182 problems
Adi316
Car  Clio 182, megane r26
Hi
Ive had the car parked up not used for quite some time until recently i got my gearbox taken out had a lsd fitted and then put back in. The car always slightly struggled to start before but now more so. When you do eventually get it goin it only revs upto about 6k and starts letting off pops and bangs which it never did before. In neutral it revs all the way up but does make abit off a gurgling type noise around the 6k mark. Do you guys have any idea of what the problem could be or if you had similar issues?
lambda with live data, crank sensor is hit and miss to check, more miss than hit as well to make it worse!!
Hi
How old is the fuel?
Here`s a little interesting read.
http://www.theminiforum.co.uk/forums/topic/218825-shelf-life-of-unleaded-fuel/
[QUOTE="Adi316, post: 11244377, member: 113084do. you think it running on v power makes any difference?[/QUOTE]
To what?
Yeah ive seen quite a few and they vary alot in prices.. cant be just £80 difference for adapter
I don't know about your car only revving to 6k , whether thats related to the crank sensor? I had a slight problem with starting about 12 months ago , it was intermittent . After reading a few posts on here I took off the tdc sensor , cleaned it and It's been fine ever since . Have you tried cleaning yours ?
Yeh took mine off this morning, found that the clip off the adapter was broken and wires were abit loose. So i cleaned the sensor and took an adapter bit off a megane and put that on but couldnt get car started at all now. Do you know if it makes a difference which way the wires are connected at all?
To be honest , I haven't got a clue about the wires . I just cleaned mine and it's been fine ever since .
'But a b**ch aint one'.
Spotted this thread a few times and have resisted until now.
Op hope you sort the issue :)
