182 RECARO seat swap
Car  Clio 182
Hello all,
I have a Clio 182 with the Factory option RECARO seats.
The driver side bolster has slight wear- is it a straight swap with the passenger seat or are all of the controls/ plugs going to be wrong?
Thanks in advance
Hello all,
Thanks in advance
It will fit fine if you swap them over but your seatbelt connections won't be on the right side. Perhaps better off finding somewhere to retrim the bolster for you?
Not sure if this is the same with factory fitted Recaros but with the Jon Foz subframes, you could swap the seats round by swapping the subframes on the seats.
Yes its possible , you just remove the seats and swap the subframes. Really easy to do.
You can more than likely change them by just unbolting the 4 bolts from under your seat without touching your steel side adaptors.
Should only take 5 minutes to remove one seat.
Just swap the sub frames over.
Seats will have a cable going from them to the runners for the tilt & slide, cant remember if the are connected to the sub frames or not.
