182 REMAP REQUIRED IN NORTH WEST - CAN ANYONE RECOMMEND ANYWHERE?
Car  RS-182 Mk2 RS-2000
Hi can anyone recommend where I can take my 182 for a remap? It has the standard ecu as far as I have heard it can be remapped. Is this correct? I am based in Warrington Cheshire. Can anyone recommend anywhere in the NW to take it? thanks Rob
Has it got cams?
If not, and it's a standard engine, then put a RS Tuner map on it - best and cheapest way forward.
If it has cams, I'd be making the trip to Paul at RS Tuning in Leeds for a custom map.
RS tuning in Leeds or as stated a RS tuner box from Fastchip with the 98ron map! I had that on my 182 made it loads nicer to drive better on fuel and defiantly felt better , don't expect big gains , but it will be a lot nicer to drive
Thanks for the quick response. This one hasn't got cams, yet... I will give them a call. I want the limiter removing and if it can give a little gain I will be happy. Thanks for the info
RS tuning in Leeds
or scoff at EFI parts in Runcorn (I'm sure they do maps)
Never heard of EFI I will check them out. Ive heard of a place in Runcorn called DAS motorsport who is into clios but don't know if they have shut down they don't answer the phone?
He just done some work on mine well impressed he's a good lad also I do rate RS tuning sorted my last car out
You don't want the limiter removing. Maybe raising slightly, but even that pointless as power starts to drop off before the limiter anyway. As a standard engine that is.
