Clio 197
I want better brakes... so:
1) AP Racing or Willwood? (4 pots)
2) Front only or front and rear
3) Will I need a better seatbelt?
Itll probably go back in a few months after for a new 6speed gearbox and some other "tweaks"Quote: Originally posted by Gary G on 15 August 2005
^ lol. Ive seen it there evertime ive been over the last 5 months or so haha. Will be awesome once finished!
Give him Yozs jobQuote: Originally posted by Fred2001Dynamic on 15 August 2005
Quote: Originally posted by Falk on 15 August 2005
How do you guys brake? I guess its more a user problem than a hardware problem.![]()
Go for standard Brembo dics/rotors 24x280mm, PFC97 pads and a good quality brake fluid like Motul RBF600 or ATE Superblue.
There is absolute no way that you will be able to cook the fluid or fade the brakes on the Ring or at any track if you use the brakes properly.
Ive taken our 172 to the Ring with this set up and I have been doing 20 flat out laps on tracks (here in Sweden) known for been really hard on the brakes.
With above set up there is always plenty of stopping ability left. No sign of fading what so ever.
PFC97s are a bit expensive, but they more or less last forever... Ive done at least 10 trackdays on my current set of PFC97s with very little wear to the pads. The downside is that you have to replace the discs more often as the pads are rather agressive, and that the wheels are beeing damaged by the brake dust. (On track replace your bling wheels whit a set of cheap 7x15" ET37 rims for the R-rubber and forget about the dust problem.)
i should give this guy a job working for Yozzasport!!!!
Hiya fred...Quote: Originally posted by Fred2001Dynamic on 15 August 2005
the 182 wheels are crap for cooling
omar, you MUST abuse your brakes fella, do you use the engine to slow down at all????
ooo, Ill have a look...Quote: Originally posted by matty w on 15 August 2005
What about tarox they do a 6 pot kit with standard size discs for about £650
The number of pots isnt a huge issue. 6 pots would be excessive. Dont forget your running a bigger disk than the williams so should cool down faster and since everyone who has used them including mark whe hes rally and tracking has never faded them I cannot see any problem.Quote: Originally posted by omar on 15 August 2005
Is 6-pot overkill on a 182? (PS std brakes are one-pot arent they).
