182 standard alarm Question
Car  FF cupped Arctic 182
I just wondered why sometimes I lock the car and it makes a series of beeps, and other times it doesn't ?
I had a look in the little book that came with the car... and still I'm clueless :o ..
Mine never does it, unless I lock it too quickly, before the door is properly shut. Other than that, no idea!
yeh there's a constant beeeeeeeeep when something isn't shut properly... but every now and again it goes beep beep beep, when I lock it.
It's not annoying I just wanted to know why sometimes it does and others it doesn't :S
Saying that mine never does it - it made that noise the other day, first time though. But still don't know why lol.
Its here its been posted and sticked the link to it for ages
Clio Mk2 alarms
http://www.cliosport.net/forum/showthread.php?t=108782
Another common problem is when you lock the car the alarm beeps 2 or 3 times.
Reason: The alarm system has received a signal from the vehicle ECU that the ignition is 'on' causing the alarm to beep. This signal is only received by the alarm for 3 to 4 seconds, after this time has elapsed the alarm stops beeping.
Solution: It can only be resolved at a Renault dealer. Ask the dealer to contact the 'Renault alarm help line' and quote reference
'RS+15'.
I occasionally get 3 beeps, when I unlock the car.
Though i'm pretty sure this is just when the car has locked itself, as I have wandered off with the keys forgetting to lock it, sort of an auto-lock function.
Can the fix only be done by Renault if it's still in warranty I presume? Mine does this and has only done it since I fitted my new grille which I had to take the bonnet sensor out to do.
The bonnet sensors are famously poor check the connections etc. Might need a new sensor they rust etc terribaly.
It tends to be ok if I leave the key in the ignition for about 4 seconds before taking it out and locking, otherwise it blips about 3 times.
i played a game today... i tried to make mine do it.
I was able to make it beep 3 times if i turned off the engine, quickly get out, slam the door and lock within a few seconds...
if i was a normal person and switched off, undid my belt, got out and locked normally it was fine.
conclusion: slow down!
:D Hey I'll try... but I'm always late !
