182 Trophy Nutley/Chelwood Gate......
Car  Meg 250/E36 Touring
This morning.
Followed through the twisties in the mist at a steady pace.
From Nutley to Chelwood Gate.
Not me but i have also followed a trophy (in my trophy) around that area a few times recently.
Not me this morning, but i do like to use the ashdown roads quite often :D
Gman is it you i saw in groombridge a few months back? Non standard number plate font on your car?
Nope i have a standard legal plate, i do get around groombringe quite a bit though as i love the roads out that way.
MistaT, do you get around crowborough at all? I followed a Trophy a few weeks back right from uckfield to pretty much my house down montargis way.
I avoid crowborough like the plague, too many scumbags around there that don't like me, i only ever go along the A26. Montargis is in jarvis brook isn't it? Not driven past there for quite a while. I love the roads down to rotherfield then towards eastbourne :D
I'm usually to be found on the 264 as i work at gatwick a lot of the time, or around the ashdown, brighton, worthing, west kent & generally around london! Do 20-25k a year but nobody ever spots me!
Edit: You can tell my trophy by the fact that i have FF rear seats so you will see the headrests, silvervisions, and a www.shedmotorsport.com sticker at the top of the rear window. Reg PK55***
Not you i followed then, no montargis is nearer the town centre rather than jarvisbrook!
I'm the same, do loads of miles but never get spotted, only ever seen two trophy's both of which ere local but i have never found out who's!
If i ever see you i'll be flagging you down, looked through a few of your posts and see that you've changed a few stereo bits and pieces, keep thinking about doing this but as you've said the standard setup isn't all that bad, wouldn't mind hearing a few upgraded systems to see what the differences are like.
Rotherfield to eastbourne, some proper good roads around that way, funny enough i drove back from eastbourne just yesterday that way:-D
Tell you what, east sussex is brilliant for driving later in the evenings, it seems to be empty most of the time :D I quite enjoy the drive cross country towards hastings then along the coast past rye and camber towards folkestone then back. Love the little section at monchelsea :D I tend to just drive and end up discovering so many great country roads that nobody uses.
If you need to know anything give me a shout, getting to know clios quite well, just changed wishbones, uprated brakes & sound system. All pretty simple stuff so far. Cambelt & aux belt next :o My stereo system is great for quality, unfortunately since i've changed the doorcards to alcantara ones they're not sealed perfectly like the standard ones so i'm making some baffles, modding the doorcards and sealing the doors with dynamat, adding a 2 channel amp under the seat at the same time, running a 250GB drive now too so there's almost limitless music :D
I've seen a few trophys locally, one at the end of ladies mile heading from tunbridge wells to lye green, and one at the roundabout in groombridge which iirc had the dodgy plate, gave them a nod...
