Tyre dependant the rear probably will rub if lowered. Mine was -60mm with 205's on and it rubbed ever so slightly on the rear. I added 3mm spacers and this solved the problem. No rubbing at the front.
I hav dci 100 not lowered with clio sport 172 wheels that rubbed pretty nasty at the rear, esp on corners. Easily fixed tho by fitting 5mm spacers at the rear, bolts didn't need replacing.
