197/200 cruise buttons compatible with 1*2
I need to get some cruise buttons so I can use the wires/connector to sort out some buttons for my Sabelt wheel.
Does anyone know if the connector is the same on the 197/200 cruise buttons? and if it is will they work, or am I better getting some Mk2 Laguna cruise buttons? (I've looked for clio ones but they seem difficult to get hold of)
@MicKPM you're a knowledgeable chap when it comes to RUK electrics compatibility - any ideas?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
From memory the connection is slightly different between the X65 and X85 but I believe the switches work.
Don't use the Megane III items as they are completely different.
Personally, when I put cruise on WZG I cable tied my standard wheel buttons to my Oreca dished wheel.... It didn't look bad either. You could also tap the wheel or make a bracket and the screw it down, if you prefer
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Pretty button yes but also pain in the arse. Just pin the standard buttons somewhere that's not on the wheel... column surround for example
