197/200 cruise buttons compatible with 1*2
I need to get some cruise buttons so I can use the wires/connector to sort out some buttons for my Sabelt wheel.
Does anyone know if the connector is the same on the 197/200 cruise buttons? and if it is will they work, or am I better getting some Mk2 Laguna cruise buttons? (I've looked for clio ones but they seem difficult to get hold of)
@MicKPM you're a knowledgeable chap when it comes to RUK electrics compatibility - any ideas?
From memory the connection is slightly different between the X65 and X85 but I believe the switches work.
Don't use the Megane III items as they are completely different.
Personally, when I put cruise on WZG I cable tied my standard wheel buttons to my Oreca dished wheel.... It didn't look bad either. You could also tap the wheel or make a bracket and the screw it down, if you prefer
Pretty button yes but also pain in the arse. Just pin the standard buttons somewhere that's not on the wheel... column surround for example
