197 steering wheel in a 182FF
  182 RB FF
Tried searching and people have said they have done it but want to know how easy it is. Is it just a straight swap. Do you need a boss or anything. Do the cruise control buttons work as normal and are the connections for these buttons and the airbag the same plugs as the 182? Thanks
I Changed My Name
It's the same diameter but doesn't look or feel it. Way chunkier and feels so much better in hand
I lobbed on my Megane, best interior mod I've done. Will be putting one on my 172 when I can be bothered to get the spacer machined🤣
GrahamS
if do you do this you 100% need a 5mm thickness spacer. Looking back I wouldn't do it again, it's way beyond my tolerance for a safe mod these days.
29mm OD 20mm ID IIRC, 5mm thickness minimum. Ideally you would use a proper machined taper to spread the stress.
