1995 Clio front bit of plastic
Car  '95 Rsi
Hello,
My Clio 1.8 Rsi 1995 seems to have had a bit of a homemade repair done on it. The front plastic bit that sits in front of the radiator and below the bonnet is now loose at one side where it had been stuck down with some sort of compound.
The picture shows where the repair had been; it has now come away totally so the whole bit is loose.
Can I just remove this whole bit of plastic? Behind it is the radiator so as well as being cosmetic I guess this is to protect the radiator from stones and the like hitting it while letting air pass above and below it.
If I can't just take it off should I get some kind of mesh to stop larger stones getting in?
lib
The light finisher is a piss of piss to get off, one screw by the grill and two prongs on the other end which clip in to the headlight.
