R
rich[182]
Firstly I am leaving the following alone, totally standard
ECU/Mapping, CAT, Suspension/Brakes
I am definitely changing CAT-back exhaust and it WILL be hidden tailpipes and WILL be either from K-Tec or Hillpower
Right, Below is my sticking point - namely Induction options.
1 - ITG panel filter, Hillpower induction pipe, improved cold feed pipe to std airbox & also unplugged from airbox for better induction noise £110
2 - BMC CDA & Hillpower induction pipe £210
3 - Hillpower full induction kit diy £210
4 - Viper & Hillpower induction pipe £280
Questions
Will either of options 2,3 or 4 give me any real noticeable gains in throttle response & acceleration over the cheapest option 1 AND will induction noise be much louder (Should induction noise be same for 2,3,4 which is loudest) or should I just go for option 1 and put the £100+ saved towards my exhaust
If Hillpower also modded my inlet manifold (£180) would that definitely mean Id HAVE to get r-sport ECU and threfore mean I cant do the inlet manifold work
Finally got my brass ready after 4 months but induction decision doing my chuffin head in - just cant make my mind up
