2.1 Conversion
  350z & 16v Maxi
This list is from the Prima site, although I wont be using them, what else do I need for this conversion either from a 1.8 or 2.0 to 2.1? I still want high revs do I achieve this by balancing the bottom end?
16V ENGINE COMPETITION HEAD GASKET -
ADJ. FUEL REG. (CLIO/19 16V PH2) -
16V 2.0 FAST ROAD CAMS - PAIR
16V COMPETITION CAM BELT -
16V VERNIER PULLEYS (ALLOY) PAIR -
16V GROUP A OIL PUMP SPRING -
16V COMPETITION PLUG LEAD SET -
16V 2.1 FORGED PISTONS (SET 4) -
16V COMPETITION ROD BOLTS (SET 8) -
4 CYL CRANKSHAFT/FLYWHEEL/CLUTCH - BALANCING -
LIGHTEN, BALANCE & POLISH RODS (SET 4) -
If my experience is anything to go by, then uprating the output of your engine must be accompanied by other upgrades such as clutch, engine mounts, gearbox casing, diffs, track-rod ends and so on.
I guess that these bits will handle increased power and higher mileage - but not together. So dont expect a car with 70k on the clock to be happy with an extra 30-50bhp! I know. I found out the hard way!
Budget for another £1000 to be on the safe side.
  350z & 16v Maxi
Cheers ben, i had already thought of them. Just meant any other engine parts. but thanks anyway.
