2 Exhaust Leaks
Car  Titanium Clio 182
Hello,
My 182 has two leaks before and after the CAT, only had a quick look but are there two gaskets/seals either side of the CAT?
How much do these gaskets/seals cost.
There is a gasket at the front end of the cat.
You can get the gasket kit direct from renault including gasket/bolts/washers/springs. ~ £27
The rear of the cat there is no gasket. Just buy a new clamp, and use some high temp silicone sealant.
Maybe the exhaust gasket where the manifold joins the cat as stated. For the rear id just make sure there are no cracks and dont be shy with exhaust paste.
