2 questions.
when i change gear, when i let the clutch back out, the car tends to judder, as if the car just jerks forward fora split second or something. any ideas?
also, when i start the engine, the coolant level on the dial is right at the bottom. this lasts a few mins, then it rises to about half way. any ideas?
by the way, itsa 1.2 16v dynamique
yeah its the crap mapping on the stock chip. Even if you let it out slowly it does it.
You have a coolant level sender?
Whats the coolent needle you sure ur not talking about the engine oil temperature. That will go up slowly as the engine takes some time to cool up all the coolent in the engine.
The juddering problem is abismal on the Micra i have at the moment. Drive a 1liter Micra then you will be happy with the Clio.
EDD
