2 things.. HELP
  seat ibiza fr
When i indicate right > the dash lights and the clock flash on and off in time with the indicator?
Any ideas why?
Also just fitting a new headunit and it only seems to work for about 3-4 seconds then cuts off, i put the standard radio back in and it was perfect?
Also tried the HU in a diff car so i know its not that :s
any ideas
thanks
  1.2 Mk2 Clio P1
Sounds like some dodjey wireing to me!
Could also be the fueses, I know that they can cause some random issues.
  seat ibiza fr
all the fuses are okay, it stays in if you can get it on after fiddling with the wires... obv a wiring issue :-(
  1.2 Mk2 Clio P1
Do the dash lights still malfunction when you have the standard HU in, or is it just when you have the new HU installed?
  Bmw e92 335d
Make sure you have a decent earth connection on your battery neg terminal, and trace the neg line to the adjoining earth points to the gearbox and body. Unbolt them clean them, lube them and rebolt. Perfect place to start in this situation
