2002 Clio dci (65) dosent start when hot just cranks but no fire
Kes
Car  Clio dci (65) 2002
Hi. I have a 2002 clio dci (65). I have bought this car a week ago. The problem is that when the engine is cold it will start straght away but when it is hot and u try to start the engine for instance you have gone into a shop and come out to start it, it will not start the engine will just crank and not fire. Also after a few seconds of cranking the coil light and stop light come on. The only way to get it goin is to spary some easy start in it or just wait about an hour for it too cool down. I have been on the net all week but can not find a for sure fix for this problem. I have cleaned tdc sensor and egr valve replaced pressure regulator sensor cam sensor and coolant temp sensor still no luck. Could it have somthing to do with fuel vapor lock. I have also read that flushing the engine could help. Has any one fixed this problem. Any help would be great full as im desprate now. Also the fan dosent work.
