Hi all,
I keep getting my ABS warning light flash on, and Braking Fault display when i make right hand turns.
I have used my dad's RAC equipment to run some diagnostics and get the fault codes;
DF001 - Computer Supply Voltage
-Abnormal Voltage
-Intermittent
DF017 - ECU
-Computer; supply fault or internal electronic problem
-Intermittent
When I last ran a check a few weeks ago, only DF001 displayed, which fits with my dads, and my own theory that it is simply a loose connection since it only happens when I make a right hander.
DF017 showed for the first time this morning, and I hadn't experienced anything other than what caused DF001.
I've literally been able to continue driving as normal with DF001, just have to do the old on-off trick and the warning disappears until I make another right hander.
Has anybody else had this fault, or have any suggestions on what it could be?
-Abnormal Voltage
-Intermittent
DF017 - ECU
-Intermittent
