205 40 16 or 195 45 16
Austin-182
Car  182
Anyone any ideas what size of the above would be better in terms of wear?
I know standard size should be 205 45 16 but they are like doughnut's!
Ive gone from having 182 cup wheels with 195 40 16's (which were wearing too quickly on the inside and outside) to buying a set of trophy turini's that came with 205 45 16's
I simply want to know what would be best/last longer out of the 2 mentioned in the thread title (on the turinis)
when you have uneven wear on one side or the outer edegs that normally indicate tracking out or over/under inflated tyres
As above.
I don't think you will notice a great deal of difference between the 2 sizes in terms of mileage returned from them.
If your worried about costs and being more pocket friendly then go for the 195's, it was only the cup packed cars that had the 205's over the 195's.
I have 195/45/16 on my clio 172 and find they last me near on a year, when i have them changed in winter they still carry an amazing amout of tread.. this said untill i had the tracking and camber checked at a good place my car ate tyres...
Tracking was all done and spot on, i think because they were 40's aswell they were so streched it made the in/out wear quickly
Maybe just go for 195 45's and see how they go
How does the sidewall profile have an affect on how stretched the tyre is? Genuine question btw, not a sarcastic comment.
^ read the f**king manual
Dont have the manual to hand, but either way it was a simple question to ask was it not....Not too sure scott tbh, just prosume as its stretched due to being 195 instead of 205, the in/outside have more contact with the road surface-may be wrong in thinking that hence starting the thread for a bit more clarification
If you've not got the manual to hand, most cars have a sticker on the B-pillar with details too.
I can't tell you for sure (and I can't be arsed to search) as I don't own a Clio, but it is something like 2.3bar F : 2.1bar R.
I posted standard 205/45/R16 tyre pressures last week, check my profile for recent posts. Any other size will likely need something different.
Personally I prefer standard width, anything narrower will just give a harsher ride in return for little real-world improvement in handling, etc.
