QUOTE !!!
Nothing is factored into a rolling road test, it is a simple indication of the output power being transmitted through the wheels
this is becoming increasingly difficult to get through to you...
IT IS NOT a simple indication of power at the wheels !!!. with nothing factored.
It is HEAVILY factored.. .
thats how it works..
instead of bringing torque and other irrelavent points to the argument
my learned friend
.. you HAVE to bring torque into it....
your xyz kw engine did NOT lose a percentage due to gear ratios on the rr.. it lost a percentage due to friction... the RR allowed for other apsects becasue they are known or can be EASILY calculated..
I am sorry if you cannot comprehend that, but please feel free to contact your local rolling road distributer or SUN themselves.. and ASK them....
and as for...
So why does my engine produce more power WITHOUT the gearbox attached -
it doesnt, it produces exactly the same... but, the output of the gearbox is of a lesser reading (from 2 factors.. friction and a multiplying / divider effect.... )this, is WHERE you are going wrong...
the power at the OUTPUT SHAFT varies, not of or at the engine.. I trust you agree ??
And again... you are not measuring the output shaft or wheels directly in the final result of a rolling road !!!. only the INITIAL data used to CALCULATE the result you, as the customer... sees....
it simply uses that to calculate appropriate figures.
The result is.... THE FIGURE AT THE FLYWHEEL MINUS A LOSS DUE TO FRICTION... but, you cannot accurately assess the amount of loss... but, you CAN say WHERE it is lost... presuming the starting figure was the same...
5 psi on tyre pressure can make 10 bhp difference on a RR.... simply due to contact area * 2 as opposed to * 1 on the road.. the tyre is not designed to be deflected in two areas in such a short space of a rev... to compare accurately you need to know all variables....
again, I am sorry, but you DO NOT seem to appreciate the way a rolling road works.
Joe.
