well after my second blow up i was pretty p***d off but decided to find out what my problem was and it turned out i had read the cam info wrong and basicslly set them with way to much overlap and the inlet and exhaust valves were tangling with each other
once i sussed that out i bought anoother engine sent it off for reboring and fit the high compression pistons again, then did my diy headwork and refit the skunk2 pro valve springs and titanium retainers and along with the stage 2 cams, with alot of help from a honda guru i got the cams dialed in correctly with the degree wheel and dti guage and needless to say they were no where near where i had set them the first 2 times.
i got it running on the sunday did a few miles then
paul@rs tuning did his magic again and i was more than happy with the result as it made 229.6bhp and 163ft lbs torque
after that i took it to santa pod for the mini show where it ran a
12.7@108mph with specky driving with a missed gear and i managed a
12.8@110.5mph the car performed awesomely and pretty sure it was the quickest na car on the day so im pretty pleased with that
here is a couple of in car vids ,
speckys run
http://www.youtube.com/watch?v=dobyvoOu4Wo
my run
http://www.youtube.com/watch?v=hwlAJhErUJg
