2into1 VGA?
Car  Liquid Yellow 182 FF
Hey,
I currently run my PC connected to my ACER monitor via its VGA lead, but I also like to run my xbox 360 into that monitor too. So, when ever I want to switch I have to keep changing the wires over. Its not a major problem, but its a bit annoying. Anyway, wanted to know if theres like a 2into1 type thing? So I can have them both connected at the same time? If yes, where can I buy one?!
I have something you can use, Its a KVM you can have it for some dosh
Its got 2 VGA inputs, and then you press a big button to switch betweem them. I used it for the exact same application you want :)
Say £15 posted
Many KVM's are s**t, i have exactly the same set up as u (acer monitor too) and I have bought 2 KVM's (around the £10-15 mark) and both show clear PQ loss, with ghosting and such so I have now reverted to just switching manually.
Having said that, the amplifier + switch posted in here will probably be spot on, the cheaper KVMs lose quality because they don't amplify the signal but that one will so you should be fine. Worth paying the extra if you're gonna do it!
EDIT: Oh s**t just realised that one posted is a 1 in to 2 out, I don't think it will work the other way round will it?
