ed_172_cup said:sounds like it could be a vacuum leak - check the intake manifold hoses for leaks...most common cause for this problem
AmirClio said:Speedo cable needs re-earthing i reckon. Take the top of the dash off, you will see the speedo cable going on the back of the clocks, the black wire is the earth wire, cut it close to where is enters the white clip on the speedo cable and re-earth somewhere on the chassis. Should sort it, if not try removing the idle speed control valve and giving it a clean.
Hope this helps!
Amir
AmirClio said:If it was a vacuum leak they tend to idle lower not higher than normal.
Zmaster2k said:wheres the speed idle control valve?
