2modified - FK Wheel Spacers
Right, im gona order spacers from old johnny2modified to fill my current 17" alloys, so they sit in my 172 wings nicely. (btw, my cars a 1.2 dynamique)
Spoke to John (what a nice boy) and he will order me a set once I get the confirmation from you lovely people.
I need to know, what "MM" (size) do I need per wheel?
"HAS" advised me 25mm per wheel...
would you agree with that.. anyone done this???
Cheers :) Jay
25mm is loads how much do you want your wheels to stick out?
You'd need longer bolts as well you know?
-KarL-
20mm still waiting for mine to come in!
also i orderd 1's that bolt to the hub so you can use your normal bolts
  Turbos.
I thought they all came with their longer bolts..?
I certainly wouldn't have 20mm spacers with std bolts, that wouldn't work surely?!
Can someone give me a price for them? I want some around 10mm.
Has
  RS 182 - Black Gold
Englebert: Most 2-10mm spaces including FKs suggest you use longer bolts.
5mm FK Hub Centric ones with bolts are roughly £50.
15, 20, 25mm +
Normally come with a different fixing. They bolt to your hub with longer bolts i assume.
Then you use your normal bolts on the face of the spacer.
The FK 25mm spacers used to come in with bolts at £175 or there abouts.
I beleive there prices have come down rapidly if the price JLO gave me are correct.
For a lower spec model to get the wheel spacing correct looking for the 1*2 wings a spacer of roughly 20/25mm is required to get the desired effect.
Also to note anything above 15mm will probably exert a lot more wear on wheel bearings etc.....
  Chocolate Bar™
obviously not. i'd go 40mm per axle (or 20mm per wheel if your feeling pedantic lol)
and in being FK's they'll be hubcentric and come with two sets of bolts.
  VRS
ah ive just seen the post about whether to sell his clio or not! i must have missed it as i thought he had bought the zimmer
btw mark i hope u have been saving up for pc pads?!!
  Chocolate Bar™
do i have to pay for my own pads?
in that case once you've finished i'll take them back :approve:
