2nd Belt change on my 182
Car  RS Clio 182
Well this summer i need both my belts doing on my 182 - had the first change 4 years ago in 2009 - so it is definatly due. I just want to ask should i get another 'big' service done at the same time - similar to the one i had around 36,000 miles?
And another quick question - I have my MOT coming up - my windscreen jet washer does not work (think the motor has gone)...will this fail the MOT? Im going to get it fixed before just to make sure.
Cheers for help you can give :)
Yes it will fail as they test them.
what do you mean by big service as the belts normally is the big service lol.
Yeah whats a big service?
Cambelts not due for another year yet! Unless it's due on millage.
Cambelt is due at 72k or 5 years whichever comes first from when it was last done.
Aux is 36k or 5 years whichever comes first (CS says 3) from when it was last done.
All the service requirements are in the handbook that came with the car, Clio 182 has the simplest I've seen.
My car Has Only done 58k is a 1.4 16 valve 2005 am I correct in thinking I need to get the belt changed at 75k?
If they've never been done they're 3 years overdue.
:( My garage have just said before 70k and it will be fine. They said age is nothing to do with it. It is the service history and mileage that effects when it is needed to be done.
Just look in the owners book, the belts made of rubber, and rubber deteriorates over time.
I could be wrong on the 1.4s, but i'm betting it's still 5 years.
I believed the garage when they said this with my first car. A month later the engine blew up into a million pieces.
Age definately effects it!
Why risk it? The aux belt failing can take out the cambelt, causing a serious bill.
This. The AUX belt change is not all that dear anyway and at least then you have the peace of mind. Few hundred quid or a new engine if it snaps and takes out your cambelt.. I know what I would do.
Do you do the Aux belt at the same time as the cambelt?
I believe it makes sense to - so if you think of the Aux as having a 2.5 year life, then you can change it in between each cambelt service.
And surely the aux has to come off to do the cambelt anyway? So really if you de-tension it then you have to change it?
It's not a risk if you're following the recommended Renault Service guide in the manual, as that states 5 years 36k.
I think if you get your cambelt done then the aux generally gets done at the same time.
I had a price of £450 for both belt kits I would imagine that means cambelt and aux.
Ive done 38K since my Aux was done so im going to have to do it. Id rather do both belts at the same time though - just means my cam belt will be a year early.
You learn something new everyday! Never hear anyone talking about Aux belts.
Aux is 3 years or 36k not 5 years?
Have a good read of this, CS seams to say 5 Years, anyone in though seams to say 5.
http://www.cliosport.net/forum/showthread.php?364986-Aux-belt-is-it-3-or-5-years&highlight=aux
Post 25 onwards is best.
Here is picture of the manual to.
That thread just shows that everyone is saying Renault recommend 3 years over 5 (that they used to say) due to failures, and you're the only guy arguing against it.
As I said, get it changed at 36k/3years if you're not a cheapskate ;)
It's kinda common sense. 36k is average 3 years driving. I think the 5 on the manual is actually a misprint.
lol no it doesn't, it shows CS says 3 years, but anyone who works for renault/has access to the ICM/know what they're on about says 5 years, (the manual, Birchdown, lemonnobby1,etc)
and Renault sport answer a question on their own website with 5 years
http://www.renaultsport.co.uk/Question/14455/Category/28/community/experts/Default.aspx
ExpertsThe Renaultsport Experts area gives you the opportunity to get expert advice from the Renaultsport experts themselves. Choose a category below to view previous questions already answered or ask your own.
182 36k service Technical
[TABLE="class: ContentTable"]
[TR]
[TH]octagon asks[/TH]
[/TR]
[TR]
[TD]Hello, I have recently bought a 54 plate 182 cup, the car was bought from a renault dealer and sold with a 'full service' as the mileage was just over 36k. Should the the aux belt have been changed as part of this service? also, as it is a 54 am i right in thinking the cam belt will need doing soon? does the aux belt have to be changed when the cam belt is done? or should i get the aux belt done now and the cam belt done when it is due? Many thanks[/TD]
[/TR]
[TR]
[TH]Allen responds[/TH]
[/TR]
[TR]
[TD]The Renault programme states: accessory belt: every 36k or 5 yrs / Timing belt: 72k or 5yrs and with the accessory belt it includes the belt tensioner pulleys. So if its 5 years old both belts should be replaced.
Regards,
[/TD]
[/TR]
[/TABLE]
Tbf it's not really worth the risk leaving it as it costs a fortune for a decent engine and to get it dropped in plus you would do belts on a new engine anyway.
I just bought a 182 on 77k belts were done at 54k in September 2010, will be getting them all done asap just for piece of mind.
He's not on about risking leaving it, he's on about just leaving it it to the guidelines set by Renault.
I know but for piece of mind sometimes its best to ignore the guidelines and just get it done anyway.
