365 ish miles...
Car  CLIOpatra, L22EE W™
Ok,
I am currently getting around 365 miles per FULL tank of fuel. Is this about right for a 16v 1.2 Engine?
I only ask, because when I fill the tank, and reset the trip computer - I get different readings. For example, it says I have got about 450+ miles til I need to fill up again. But am only getting about 365+ miles. Also, I guess it depends on how you drive the car, etc...
Sounds similar to what i get. like u say depends how u drive, sometimes I only get 320 once I had 400ish
If you fill up and set off say on a motorway journey you`ll get better mpg so the comp will work it out using that mpg.....once you`ve stopped at lights or hammered it a bit the mpg will drop and so will the estimation (assuming it`s the same as the 172`s comp)
Chris
My Trophy averages 26-28mpg (according to computer) and I get about 240 miles per tank. I don't let it get fully empty. Computer normally tells me i'll get more than 300 miles to a tank! And i do occassionally have the odd spirited drive!:cool:
Your mileage to tank sounds about right!
I'm really impressed with my 182's mpg. I tend to drive the car like it was intended but can still get between 270-300 to a tank. And alot of that is in town too.
usually in my 182 i get between 325-350 on a full tank, I dont use the car to commute so alot of the time Im on A & B roads which obviously helps
:O
I filled up last night, reset the counter thing, which now says 96. something and I'm on the 3rd dot of the petrol gauge :o And mines only an RT!!!! :(
im currently getting around 270-300 from a full tank but im in traffic alot coming too and from work.
pompymatt- sounds as if you have a problem or you have a really heavy foot!!!
