4 Pots fitted......
If anyone's fitting 4-pot calipers for looks, well, fair enough.
If you're fitting them thinking they work better, that you somehow get better braking and/or better fade resistance you really need to ask someone other than the salesman who is selling them to you.
Its a matter of piston area. The more the piston area the more force is applied to the pad for a given amount of brake line pressure. This is why performance bikes fit 4 and 6 piston calipers, because they don't have power assistance, so the amount of braking you get is limited by the strength of your hands, so their benefit is increased piston area. Race cars fit them for a quite different reason. You have really sticky tyres so you want a lot of pad area to get enough friction to use all the grip you've got on the road. To do that with a single pair of pistons they'd have to be huge, so you use multiple pairs of pistons to create a caliper that's compact so you can fit as big a disk as possible.
Its not the 4-pot caliper that improves fade resistance. Its the size of the disk. The mass and its ability to pump air through it to get rid of heat. A 4-pot caliper is longer and thinner so lets you fit a bigger diameter disk inside any given size wheel. So if the road car has power assistance and isn't running a bigger disk its really hard to see the point.
Your also not considering that a cast iron caliper flex's, and the act of oposing the pistons creats a much more positive and even pressure on each side of the disc. The aluminium bell and caliper also helps to disepate the heat much more efficiantly.
He's not talking about those though, he is specifically stating the advantages or lack of of just sticking more pistons on. But yes, there's other advantages to your setup.
PF's turned my silver car brown (couldnt remove/restore without a respray), excellent pads tho.
I just got compbrakes too...But my calipers are different to them! Amazing quality.
See on the bak of the caliper did you use the 'L' piece...I've got a few bits and pieces...that tbh i'm not sure where they go..
Off compbrake site these are the calipers, i think they are the same but they have 2 different names!!!! They might have changed the pad mounting on the calipers since mine where done.
http://www.compbrake.co.uk/compb43.htm
The clio kit spec.
http://www.compbrake.co.uk/Renault Clio.htm
What do you mean by L piece? Mine came with the calipers mounted to the brackets so i just bolted them on. Im doing some other work on the car wednesday night so i will take a pic of the mounting bracket etc.
\The clio sped kit is exactly the same as mine...Caliper design is diff to yours. The pads are mega diff to ds2500...There a flat design.
they look a bit bremsport'ish and no dust seals on a road car.....good luck, i had wilwood superlites on my escort turbo and was forever cleaning the pistons was dead chuffed with them in the mean time. IMO those brakes are overpriced too as rally design knock out wilwood brake kits for half the price for fords dont cost much for bells and brackets to be made up all my own opinion though no offence intended.
thanks chris
^^ Depends on the willwood kits, most use the cheap cast calipers that are made in China/taiwan/vietnam etc. They are known for being porus and not the best. The proper American Willwood calipers are worth having, and a decent setup built using there modular setup would cost comparative at around £800, i looked into doing this before these came up and i would have had to get a few bits machined and it would have been a bit more hassle than buying a new Compbrake kit.
