428s on standard ECU management
Car  e60 M5 -172- dciheid
Im aware you can run 428s on standard ECU management, but prior to being mapped, which i know will unleash their full potential, i take it you can still drive around with the new cams, but for how long?
You "will" be pretty much ok... as long as you don't go bouncing off the limiter at every moment LOL!!
Yeah pretty much... PH-reebone has fitted some 428's and not had the car mapped, said it seems fine
coolio. didnt think there would be a major issue with it, just doesnt 'unleash' the full potential of them
mine was drivable on a standard map with the 428's,just a little bit iratic on idle when cold but soon went when up to running temps,the map sorted it out sweet tho,rs tuning are awsome
