51 plate 172 owners!!!
hi guys sorry this is a bit silly but just wondered what mileage my 51 plate bretherins had racked up i am sitting pretty at 57k? anyone got to over 100k yet
  172 Ph2
76K New,cambelt, discs, pads, hose's, zorst, dampers, springs, coil-pack, leads, plugs, cat, tyres, wheels, air filter, airbox, plugs, temp sensor........want me to go on????? It's gotta be better buying a 70K cat than a 50K car as most of the work will have been done!
DrR
  VW Golf GTD
Mines on 54K going to need a new gearbox put in, arg, but think thats my fault.
  Clio T 314hp c43 AMG
51 plate 2002 45,000 miles............ cambelt/tensioners, altenator belt, both rear wheel bearings, rear pads, front pads x 2, about 8 tyres, x3 rear dampers, centre exhaust section, cat, drivers door latch complete, aircon pipes, battery, headlamp amp, igniter and bulb thats about it then all my mods :S
o yeah and a gearbox and clutch thanks to santa pod lol
think im lucky touch wood as mine only has 21k on it and i bought it from renault who changed all belts and fluids along with a full service so should last me at least 2 yrs until i buy something bigger :)
Pep
Living Dangerously
  M2,XJS,S1000RR
matty j, im sure i've seen you around a few times, you ever drive around spondon??
Pep
Living Dangerously
  M2,XJS,S1000RR
yeah i live in spondon.
didnt know there were any members around derby, only seen about 3/4 around!
Pep
Living Dangerously
  M2,XJS,S1000RR
cool, ill keep my eyes open for you!
cheers guys thanks for the posts so far makes interesting reading do you think will all the money spend it still makes it worth while?? i have only had to replace the rear shocks on mine since having it and fitted apex springs but thats through choice!! need a new clutch cable though now as it stiff as!!! oooo errrr!!! plus the exhaust is about to drop of fully but that just wear and tear!!
Danith
  GTi 7.5 pp/Mx5 nd2
im on 84k. had no probs yet apart from new radiator in summer cos fan dug into it and put small hole in it, new bearing on back and new discs/pads. oh and timing belt done at 72k. i bought it on 69k.
