only way of knowing 100% is put wheel on full lock, head under arch and measure the spacings mate. It seems to be a bit of a lottery! Most likely 58mm spacings tho as it only seems to be early (2001/2002) 1.2's that got blessed with 52mm
there is no consitancy between the spacing, suspension wise, springs are ok, spax kits are better, fk high sport kit is better better and fk coils are better better better
K-tec have the APEX kit that most of us are using on our 1.2s for £270 in 58mm spacing only way to find out is like said above, put your steering to full lock and measure the space between the 2 bolts where the damper connects to the wheel hub will be eather 58mm or 52mm but 95% chance its 58mm
