58 0r 52mm spacing
i have clio extreme 03 does anyone know what fittment this will be as i don't know how to take this apart and put them back again. many thanks
Da
  Less
only way of knowing 100% is put wheel on full lock, head under arch and measure the spacings mate. It seems to be a bit of a lottery! Most likely 58mm spacings tho as it only seems to be early (2001/2002) 1.2's that got blessed with 52mm :(
  C63 AMG, F430 & 172
there is no consitancy between the spacing, suspension wise, springs are ok, spax kits are better, fk high sport kit is better better and fk coils are better better better
  C63 AMG, F430 & 172
mmm id go 16's for 300 id defo go for the highsports, there mint had them on ma old car , was like a go kart!
Da
  Less
depends on what kinda drop your going for? 35-40mm 60mm or more? 17's are big but all depends on your drop.
Get a suspension kit them Apex do a 40 and 60mm kits for onder £300 I think.
Most likly your cars 58mm though.
  C63 AMG, F430 & 172
hard, run 16" on 205 16 45. if u want 17"s then u gotta drop it 60mm to look right imo. the fk is 60 front 40 rear
my old car with the kit with the 16s
looks really good
but did it rub at all when driving
my problem is, if i am lowering 40mm and then putting 17's on and all it does is rubs i don't want this effect....
Martin_172
K-tec have the APEX kit that most of us are using on our 1.2s for £270 in 58mm spacing only way to find out is like said above, put your steering to full lock and measure the space between the 2 bolts where the damper connects to the wheel hub will be eather 58mm or 52mm but 95% chance its 58mm
  220 Trophy, 172 Ph2
This a 35mm front and 30mm rear.
  C63 AMG, F430 & 172
my car never rubbed on 70mm. seemed fine , there was a lettle scuff when i changed but never atch rubbed , nihere has dutty_112
  BG 182 FF
ben p...you from widnes? im sure iv sin that clio with white alloys outside the sixth form in widni...a while ago like
  Lionel Richie
lol, TOO many amateurs when it comes to lowering on here
rubbing on 35mm!! pah, i only get rubbing on full lock -100mm
