A/c delete
Philip Griffiths
  182 cup
hi. New to the forum and clios. Wondering what's needed to do that aircon delete. I've got a 182 cup.
Is it just a case of a shorted belt or so I need different pulleys and brackets etc.
Sorry if this has been asked loads before.
  Clio 172 Merc ML55
What's difference with the 172 alternator? Does it mount differently?
It does indeed, different bolt on brackets attach to the block and also uses a manual aux belt tensioner rather than the auto one on non cups.
id go for a power steering delete too while you are at it, some of the pipe work is prone to failing and not cheap or easy to replace, ours did on the ring, fitting EPAS with variable assistance was the best thing i have done
