A few problems that are driving me mad !!
DrewBear11
Car  Focus ST
Hiya guys
My 182 Full fat is slowing driving me mad, ive got a few issues that i could use some advice with
Lumpy idle - ive got a poly bush dog bone but the lumpiness has definitely got worse recently.
Revs dropping low on full lock - the revs drop down to around 500revs on full lock and then come back, this is very very annoying when trying to park or manoeuvre in a small space, it wont stall but its not far off.
Revs dropping down when starting the car - again the revs drop at first down to around 500RPM then come back to the normal >1000 + cold idle.
Doesn't always do this when the car is warm mind, seems to be pretty random if the car is warm.
Reading on the forum this seems to be a dirty throttle body ? Can anyone confirm this or anything else it could be ?
On a different note, I fitted two new rear exhaust hangers recently and ive managed to shear off one of the bolts from the hangers into the mount, does anyone know what size these bolts and where I could get one or I imagine I'll need to buy a set ?
Also, does anyone have any pics of how the manifold to cat gasket should be lined up, its blowing a bit and annoying me! Ive got the kit from KTEC which I read on here does fit and is the correct kit ? Correct me if im wrong..
The car is due a service, so I'll be doing an oil change, new oil filter and new standard spark plugs (PFR6E-10) and clean out my JMS V6 airbox.
Thanks for any advice guys :)
I can only help you with the cat to manifold problem. Yes your right only use the oem kit as the others don't fit well. It'll probably blow worse lol.
West Renault on here are doing the oem kit for 24 quid. Find them in the traders section.
I've hot mine set as follows
Caps go in the manifold first, then put the bolt through them and the cat (with the donut gasket in place) then put the spring over the bolts then put the fibre washer on, then the little end caps and then the nut.
Hope this helps.
Righto mate, i'll order a new kit off wests later. Cheers man
Anyone got any ideas about my other issues ?
Rev problem could be a sticky throttle or possibly a TDC sensor. Clean the TB first if not get it on the computer to see if any codes have been thrown up!
I too have the revs dropping on full lock issue, its pretty annoying when parking like you said. So its just the TB need cleaning ?
Cleaned the throttle body this morning, it was a bit junked up. Better idle, revs not dropping on full lock and ive started it twice so far and its fine :) lovely job !!!
Must have been a coincidence, itd back to the way it was before now, not amused ! mot this week so i'll get it on the computer and see what it says. Any other possible causes to my problems ??
Erm, it was quite a while ago, its the JMS V6 airbox, im just waiting for some cleaning fluid to turn up.
Gonna be serviced this week, but could a shagged battery be causing these problems ? especially the starting and full lock issues ?? Cheers
Hello, read your problem I can suggest the following if I may...... Check the PAS pressure sensor it is located right below the Fuel Rail Guard. What this does it indicates the ECM the engine is being subject to higher demand at idle and it rises the rpms so it wont stall, kindda like the A/C strategy perhaps you have noticed that at idle u turn on the AC and it rises the rpms so it wont cut out. Let me know if it does the trick on your Clio!
