Need to do this on my ph1 (mine has the fuel pressure regulator if it makes a difference)...don't want to do it wrong so help or a guide would be appreciated
When you disconnect the fuel line from the rail you'll get a very small amount of fuel leak out. Nothing to worry about as long as you're not smoking at the time. I didn't bother trying to catch it or anything.
Hopefully not needing to replace the fuel rail now and only just the the fuel hose connector.... but thanks for the information as I will still need to disconnect the line
