Now its been running through my mind abit latetly and im just curious to see if this problem would cause a car not to run properly or even cause none starting issues.
The Inlet manifold on the F4R is good, but with that oil breather on top under the inlet manifold(egg shaped seal) could this cause some problems? basically since that does spew some oil out through the top, and you have 2 sensor's one for the MAP and the other one, could the oil cause these to block and suffocate the engine?
Answer thats suppose to say in the title, can a mod change it please
