ABS and CV Boot Help
Car  Clio 1.2 MK 3
Hi
Got my clio phase 1 sport on friday and I'm just doing a few things before mot,
First of all the front drivers side cv boot has split so need a new one, where from??
Second the abs was kicking in at low speed , looked at the drivers side abs ring and it has a tooth missing? Again where can I get one from and how hard to change??
Thanks in advance
Tom
Go to your local motor factors and buy a stretchy universal cv boot and a fitting cone. Its only a 2 hour job, drivers side shaft just slides out the gearbox without losing any oil so its the easiest side to do
Or if you don't want the hassle/haven't got the tools to hand - expect around £140 for the job to be done at a dealership. Obviously, cheaper elsewhere of course.
D.
Ok got the parts from a local motor factors, what size nut is on the hub?? My teng tool kit only goes to 21mm :/
Tom
