Abs and esp lights on
Car  iceberg phase 2 172
Hi guys, this last week the abs light and esp light have come on on my 52 plate 172, but they only come on when I go over 30mph,then when I switch the engine off etc an back on they go out, until I go over 30 again, the abs don't kick in etc or cause any problems, also the serv light aint on, anyone have any ideas?
ABS Ring might be broken / cracked or a ABS Sensor might be faulty.
You can check the rings your self by having a look at them and best way to find out if its the sensor is to get it plugged into a Clip.
I had 3 stuffed ABS sensors and the clip pinpointed each one.
Won't that make the abs kick in tho? On my old 1 it had the wrong abs rings on the back, and every time I pressed the brakes the abs would kick in and the pedal would go solid
Been told it's just the brake fluid needs topping up, does this sound right?
Yeah that also brings the lights on, Have a good look and check the level of it.
If it was me i would do a full brake fluid change but thats just me and its not needed, A top up would also be fine
