abs and serv light on ...
  iceberg phase 2 172
had my rear discs and pads changed today, all was fine until i went over 60mph, both the abs and serv lights came on, also the abs kicked in, i turned the engine off and started it again and the lights went off, drove for a bit and the abs kicked in again, but again no warning lights until around 60mph .. anyone had this before and if so what was it ?
  Clio Dynamic 1.2
I have the exact problem and have a desperate threat on here regarding this and was told its the ABS ring cracked and possible oil on shaft so have that checked out by the people who did your breaks man
  iceberg phase 2 172
found out what mine is , the spacer that goes between the disc an the hub has shattered , can these be bought separate ?
