abs and serv light on.
Car  2003 clio 172 ph2
airbag and serv light on.
any ideas? i have tried playing with wires under the pass seat but to no change..
i heard i might need a new ecu and that would have to be re programmed im guessing.
but any over ideas?
TITLE WAS MENT TO SAY AIRBAG
its all standard, haven't tried the drivers side.
on the passenger side where you can turn air-bag off or on i turned that on and it made no difference whilst messing with the wires.
ill try under drivers side tonight and see what i can come up with.
any other ideas so i can do it all at once?
This may be of help http://www.cliosport.net/forum/showthread.php?108607-Common-Clio-problems
It says this
Seat belt warning light
The SERV and AIRBAG lights come on its a common problem (almost every has it) its due to the wiring of the pretensioners going to an open circuit. Fiddle with the wires under the seat an the problem will go away.
On the early cars the solution is to look under each of the seats. You will see a grey connector.
On the passenger side disconnect it and cut the Blue and Brown wires off both sides. Then solder the Blue wire to blue, and the Brown to the other brown. Make sure you use insulating sleeves over the soldered connections..
Under the driver seat there are two pairs of wires in the grey connector.. Only cut the Blue and Brown wires and solder them together as above.. Reconnect the connector..
On the facelift cars it is ONLY the passenger side connector that is affected.. So again cut and solder the Blue and brown wires.
