Abs and Speedo Fault
Car  Renault Clio 1.4 16V
Working on my cousins 2003 1.2 Clio Billabong... Starting the car up after a long journey, she turned on the ignition with all lights coming on normally the car starts but, the ABS Light, Parking Brake Light, and Service Light all stay lit... Have also noticed that the ABS does not kick in at all... Also the speedo is not working at all...! Have been told that the problem is related to the ABS and or Speedo sensor and that is it is combined? Can someone tell me which sensor to go for? Or any other ideas as to what would be the problem?
Thanks! :)
ABS sensor - the speedo on most Renaults is taken from the rear ABS sensor. If a sensor fails it willl bring all the lights you have mentioned up on your inst panel + the speedo wont work. Worst case scenario ABS pump is knackered
