ABS ESP & SERV Light when driven on
Car  172
I know this has been posted before :( but ive got a question for all you Renault nuts :) when accelerating (Hard) my Clio 172 the 3 lights ESP SERV & ABS lights come on only after the car dies in power speedo going up and down mental and when i press the brakes the abs is on (Very dangerous causes the car to go in a spin:S) so did anybody have the same problem thanks for you time reading this post....hope its an easy fix.
I had the same problem on my 182. I replaced the brake pedal switch, but the lights still came on. I then adjusted the new switch and it solved my problem. You just adjust the switch so that if you just tap the brakes, the brake lights should come on...
