Clio 182 FF
Hi all,
I’ve got an intermittent issue, and in fact the previous owner warned me about it when I was buying the car and said that they’d failed to get it fixed and simply put up with it! Unfortunately I am not the type who can just ignore a problem, now I know it’s there I have to get it fixed.
What happens is that midway through a journey the ABS + ESP + Service Lights all come on simultaneously. Turning the car off and on again turns them off. I’ve had the lights come light up on two successive days, but then not come on for two weeks.
When the lights are on the brakes still work etc, but I think I could hear the ABS pump firing every time the brakes were used for the rest of the journey (I need it to happen again to confirm it was the ABS pump and not a noise in my head!)
So I’ve plugged my RSTuner in (Firmware 1.85 with the Mk2Ph2 ABS Module) and below are the errors it found:
Note that at the time of scanning the lights were not illuminated; the error had happened on a previous outbound journey but then cleared by the return journey home. Next time the lights illuminate on a journey home I’ll leave the car running and plug the RSTuner in whilst the lights are still on and the error is active rather than previously stored.
Any ideas on what might be causing this? Do the error messages mean anything to anyone?
Trying to think about what might be the cause I remembered that one time when the lights came on I had just hit an unavoidable bump. Also because it’s both the ABS + ESP lights coming on I’m trying to think for a common factor between the two systems, and my idea is that both systems use the wheel speed sensors… and a wheel speed sensor missing a rotation could indeed be caused by a bump.
However I obviously don’t want to go round replacing sensors at each corner without knowing it’s a wheel speed sensor at fault and in particular which one!
So yeah, any suggestions on things it might be or ways to narrow it down would be gratefully received!
Cheers,
Ed.
Cheers,
Ed.
