Abs fault
  Clio 182 sport
Hi I'm new to this but needing help with my Clio 182 sport 55 plate
The abs traction control and serv lights are all on my dash got it plug in
And it said it was the left hand sensor I replaced the sensor but still all
The lights are on any one got any ideas ? Thanks
  clio 182 cup
check the abs target on the driveshaft,it might be broken and picking up wrong signals
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
I got this before. And the other night. I was sat chatting with engine running with foot on brake for a good 15 mins so thought it may have something to do with that. It went off after ignition off and on :-/
  Clio 182 sport
Yeah checked the abs ring as well it's a new driveshaft with a new ring on it.
I'm totally lost with it ha
  Clio 182 sport
Just from a motor factor. When I first replaced the sensor the lights where out but when I moved the car the lights came back on
  182
iirc abs sensors are a dealer only part as the motor factor parts a shoddy and cause problems like you have
