Last night after gettin a flat tire the ABS light came on the dash. Got the tire fixed and its still there. Anyone know why it would be on?? Brake fluid maybe needed??
prob not the same as different cars but my ABS light was on in my old sax, and ended up costin about £270 to get fixed! something to do with the sensor, not good tho!
hello to you
hope i can help
when you got the flat,the abs system detected conflicting information from your wheel speed sensors therefor put on your abs light on.
heres a few ways to turn it off ( i hope or ill look a t**t):quiet:
sit in the car,turn the ign on and off about 6 simes for a few seconds at a time then start the engine and drive it for a few yards and it may go off.
or you can disconnect the battery leave for 5mins then reconnect it (the light still may be on) then drive it again for a few yards an it should go off.
Yea it goes off once the ign off and on but comes back on when i brake comin up to a junction/corner etc. Gonna get some brake fluid tomarrow hopefully and if that dont work get the brake discs/pipe lines looked at.
I wasnt joking about adjusting the switch by the way. A few people here have had this problem and from memory, it turned out that the brake light switch needed adjusting.
