ABS Pump
  Clio 182 FF
Hello, I'm going to change the ABS pump on my 182. I've got one from another 182 as I've been told its a straight swap. My question is about the bleeding. Can I bleed normally without plugging into a computer? TIA
R3k1355
Absolute wetter.
If you've got a dirt road nearby you can rag it down, brake hard to set off the ABS then bleed the brakes.
Rinse and repeat till it's good.
