ABS Sensors
Car  182
Been having problems with my brakes for a while. Just had the front discs + pads replaced and also a rear wheel baring which the garage thought were causing the problem. They said that the ABS sensors are split which is probably causing the problem if I still have it. Does any1 know what that means? Also how much are the sensors if I have to get them replaced?
The ABS sensors are like Cogs on all four wheels - they couple-up to a speed measuring device.
So if they're worn or incorrectly fitted, the car thinks the wheels are doing something else.
